how to hold the maximum peak value ?
i am using Daq  assistant and i am using peak detector to get the maximum of the peak.
My problem is i want to hold that maximum value till i get the next  value which higher than previous maximum value. please help
(4,633 Views)
Use a **bleep** register to hold your maximum value.  Then use Max & Min with this stored value and the new maximum to keep the larger of the two.
(4,623 Views)
Shift register .....    and know the question is what crossrulz wrote and what the 'auto correction' made out of it 😄 😄
Greetings from Germany
Henrik
LV since v3.1
(4,619 Views)
crossrulz
Appreciate your idea. But still i am finiding difficulty in holding the old value to match with the next high value.
(4,574 Views)
Please show your code. No one can fix what you've done just by your saying you are finding it difficult.
(4,571 Views)
