 Horner
			Horner
			12-07-2007 11:39 PM
 jaced
			jaced
			12-10-2007 12:45 PM
Hi Ray,
With regards to the heart rate measurement I believe this forum answers your issue. Then based on the RR data that you will receive you can use a case structure implement your alarms. I have attached a very simple VI that illustrates this concept. I hope this helps!!
12-19-2007 10:47 AM
 jaced
			jaced
			12-19-2007 12:55 PM
12-20-2007 10:52 AM
 jaced
			jaced
			12-20-2007 02:09 PM - edited 12-20-2007 02:10 PM
HI Ray,
This error seems to be coming from the Waveform Peak Detection vi, Based on the error it appears that either your VI or a sub VI has somehow become corrupted. The first thing that I would try is to copy your entire VI into a new blank VI and attempting to run it. If this does not work then in order to narrow down the source you could simulate a waveform and use the Peak Detection VI in a test VI. If none of these trials change anything then I would suggest repairing your installation of LabVIEW. This can be done by navigating to Add/Remove programs>> National Instruments Software>> LabVIEW 8.0 and selecting repair. You can also attempt to run this VI on another computer to verify that it is not something wrong with the programming but rather a corruption. With regards to the filter parameters in the VI that you posed there are no controls on the terminals so I am assuming these are incomplete, but I have attached a screenshot of how to set the default value for a control. I hope this helps!!
12-30-2007 11:22 AM
 jaced
			jaced
			12-31-2007 03:11 PM - edited 12-31-2007 03:12 PM
Hi Ray,
I believe that the issue stems from the inherent discontinuity in the ECG signal. I believe that taking a derivative is unnecessary and that the following method should work. I believe something like this:
should work if used on your waveform data. I do not have a ecg signal so therefore cannot test this. If you could post some of your data that would be helpful. I do however believe that this method should give you satisfactory results.
01-01-2008 01:04 PM
 jaced
			jaced
			01-02-2008 01:30 PM
Hi Ray,
Happy New Year to you as well! I have been unable to open the document as a .tdm file. Did you just change the extension or did you modify it in some way? I suggest zipping both of these files into a single .zip file and attaching it, that way no modification will be needed. Have you tried my suggestion from the previous post if so what were the results?
