Multifunction DAQ
how do i determine how much memory my pci-6115 has?
I see two memory ranges in NI-MAX.
Does my PCI-6115 have  32 or 64 MB memory?
Memory Range 1: FE9F7000-FE9F7FFF
Memory Range 2: FE9F7800-FE9F8FFF
(3,588 Views)
There are a couple of ways to determine this.  You could look for the sticker with the part number on the card.  If it is part number 778534-01, then it is the 32 MB version; alternatively, part number 778554-01 is the card with the larger memory option.
The other way to check is using a property node.  For more information, look here
-Christina
(3,573 Views)
Thanks, but I do not have a 7785...part number.
Here is my part number: 184529D-01. Note there are also, two memory board installed, both have part number 186612B-02.
(3,559 Views)
Accepted by topic author reichenbach
That is an older part number for the the 32 MB board.
-Christina
(3,529 Views)
