Multifunction DAQ
how do i deal while acquiring data rising ni9237
Hi everybody,
I created under matlab a code that acquire data from four gauges fixed to a beam using NI9237, the aim of my code is to estimate the applied force to the beam, my problem is that at the in the end of acquisition i get the expected force devided by 10(7000N rather than 70000), i am pretty sure that the problem comes form the NIdevice, does any one of you have a suggestion?
Yours Faithfully.
(4,337 Views)
Hello ismailel,
You can test your device using NI MAX by following this tutorial:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGZPCA4&l=en-US
Last version of MAX:
https://www.ni.com/en/support/downloads/drivers/download.system-configuration.html#307147
Jovan N. - Application Engineering
(4,284 Views)
Thank you for your reply, what i've done is i that i created a task to calibrate the channels and the results were good but now that it's done i need to know how to apply this calibrations in real channels  so i can get data corectly???
(4,253 Views)
