Multifunction DAQ
how do i connect thermocouples to the SCXI-1102?
I've been using a SR630 thermocouple monitor to read termperatures. The thermocouples are K-type and they are connected to the SR630 by a positive and a negative wire. I just found the SCXI-1102 module and I'm not familiar with the pin connections. How exactly do I connect the K-type thermocouples to this module?. Additionally, I need to read measurements from 3 oxygen sensors which give voltage readings from 0 to 1 V. Can I use this module to read the oxygen sensors as well?. We also have a SCXI-1102B, SCXI-1124, SCXI1160 and a cRIO-9151 if it makes any difference.
I just got introduced to NI products 2 weeks ago so I will probably need more detailed information. Thanks
(2,789 Views)
Which terminal block do you have connected to the front of your 1102?  You would simply need to connect to the positive and negative terminal on your terminal block.  You'll want to read the manual of your terminal block for more details (it will include a pin out diagram of all the channels).  Your oxygen sensors will connect the same way.  Take care!
(2,778 Views)
