Multifunction DAQ
Is the PCI-6034E compatible with TBX-68T?
Is the PCI-6034E compatible with TBX-68T for use with thermocouples? I seem to get either errors or bad data using MAX to set it up for either voltage or temperature.
I can get good data using the same TBX-68T, same thermocouples and the NI 4351 that is in a different computer.
(2,817 Views)
Hi, the TBX-68t can't be used with the PCI-6034E.  It is only compatible with the 435xseries.
(2,807 Views)
