how can i connect a quadrature encoder to daq pci-6036 to count in up and down
how can i connect the Z terminal of a quadrature encoder to reset the counter of a DAQ PCI-6036E
(3,530 Views)
Although the E series cards allow to use quadrature encoders, I'm afraid that their DAQ-STC counters don't support Z.
The default pins
for the new generation of M series cards are listed here. Obviously, the default pins can be changed through DAQmx property nodes.
(3,528 Views)
Hi Yasser,
All E series cards (PCI-60xx) do not support Z indexing.
You can use a separate counter on another board to measure the Z index.  This line will pulse every time it makes one complete revolution.  This line is intended to measure absolute position of the encoder.
The advantage of using a M series board (PCI-62xx) is it does support Z indexing.
Respectfully,
Rob F
Test Engineer
Condition Measurements
(3,497 Views)
