Multifunction DAQ
help to find national instrument AT-AO-10 board
Respected sir,
I am kindly request to help me to purchase national instrument AT-AO-10 is an Analog Output board or other equavalent board.
I am using labview 5.1, fieldpoint FP 1000, NI-DAQ 6.5, Field point explorer version 1.6, Measurement and Automation Explorer 1.0.1.
my probelm "connection to acquisition board was not found" when i run labview program is due to DAQ board was not there in my CPU, so o plan to purchase NI-DAQ board.
I am here sending some details related to AT-AO-10 board.
configuring device 1: AT-A0-10
system
device No: 1
Resource
Input/output range 0* 140* - 0*15F
interrupt request  11
interrupt request  9
direct memory access 6
AO
polarity Bipolar
Output Channel type voltage
if i click run test panel
i received command as
The device did not pass the test would you like to continue anyway
if i click yes
test panel window is open
Device name AT-A0-10   Device No: 1
Analog output
DC voltage is selected
Digital I/O
line state       Fatal      Fatal                  Fatal
                      error       error                 error
line number   3              2             1           0
last error -10401
The instrument was run by labview version 5.1 for temperature measurement in windows version 95.
The Field point instrument FP 1000 and RS-232 port is using.
NI-DAQ 6.5, FieldPoint Explorer version 1.6,
Labview 5.1 is compatability with labview 8.2, so i installed labview 8.2 in another computer operating XP.
Further i also installed FieldPoint 5.0.1 and NI-DAQ 6.9.3.
Kindly help me to solve my probelm.
Thanking You
Yours faithfully
M.Vijay
(3,027 Views)
Dear Mr. Vijay,
unfortunately the device you are looking for is a very old device (legacy) and I think that will be very difficult to retreive it. You can find equivalent (similar) devices, such as the ones reported here
https://www.ni.com/en-us/shop/category/multifunction-io.html?productId=118688
You have only to decide which one is the right for you, but it depends on your application requirements.
Andrea
(3,014 Views)
