07-31-2012 03:19 PM
I apologize if this the wrong forum to post this question. Please move it if necessary.
I just ordered a NI PCI-6221, 37 pin DAQ board to replace an old one. The old one has a different cord connector (non-37 pin) and has "connector 0 (AI 0-15)" printed on it. Is there an adaptor available that will allow me to use my new board?
Thank you,
Jerry
07-31-2012 03:29 PM
Sorry, the I/O connector of the old card is 68-pin VHDCI female and the new one is a 37 pin
07-31-2012 09:40 PM - last edited on 04-24-2024 02:49 PM by Content Cleaner
I have a similar problem with 50-pin DAQ card. You may want to look at using the connector block such as shown in http://sine.ni.com/nips/cds/view/p/lang/en/nid/204051. One end may be connected as screw terminals. You might find it less work for you if you use 68 pin connector block like NI SCB-68 (P/N: 776844-01) or CB-68LPR (777145-02) or NI TBX-68 (777141-01). One end of 37 pin cable wires would screw into the screw terminals of the connector block. Just my 2 cents after puzzling through connector maze.
08-01-2012 08:49 AM
Hi Jerry,
I have been looking into this, but unfortunately I have not found a better solution than what bopja mentioned above with using the breakout board. It was my hope that you would be able to use 68-pin VHDCI to 68 D-Type then to a 37 D-Type, but this has yielded no results. Aside from using the breakout board you might be able to purchase each connector types and make your own cable.
08-02-2012 02:28 PM - last edited on 04-24-2024 02:49 PM by Content Cleaner
Hi Jerry,
I was not aware at the time of my last post, but there is a 68 pin version of the PCI-6221 available. If you contact your Account Representative they would be able to discuss your options and possibly setup a exchange. Here is a link to that device. https://www.ni.com/en-us/shop/model/pci-6221.html
