error 50103
Hi there,
Can anybody help me please... I'm not so new on labview and never had a training. I am trying to rea measurements from different temperature sensors using NI9203 channels and also i'm generating output signal from NI9263. I need to see all temperature running at the same time but when i run labview i get error 50103. I have tried all steps mentioned on previous report ofsuch error but still cant get my measurements.
Please help me...
Message 1 of 8
(5,527 Views)
I'm guessing that you are using a cDAQ-9172 CompactDAQ chassis.  You are getting a resource reserved error because you can only have one hardware timed analog input task and one hardware timed analog output task running at a time.  Looking at your VI, it's a simple fix.  You'll want to add all of your analog input channels, for example, to the same DAQ Assistant block.   Just open it up and click "Add Channels".
Message 2 of 8
(5,518 Views)
Hey thanks for the prompt reply. Yes I know what you mean, and had done that already, the problem is that i want to have individual display for each signal. And that way i can only manage to have a graph with 23 signal, that way i am not able to see clearly the variations in each channel as i would like to... is there a way I can use somethink like a demultiplexer to read each channel individually?
Message 3 of 8
(5,496 Views)
Accepted by InasLab
Right click on your data wire.  Select "Signal Manipulation Palette".  I'm fairly certain "Split Signals" will do what you want.
Message 4 of 8
(5,483 Views)
Thanks for your suggestion. I never new there was something called split signals "I'm so used to matlab that i thought it would be callex mux/demux".
I still can not do that for the NI9263 it says "Error 200524" More tasks than it is allowed. I want to control a selenoid, and some actuators but i dont know how to make all work simultaneously in one block.
Please have a look at my file
Regards
Message 5 of 8
(5,469 Views)
Error -200524 does not say 'more tasks than it is allowed'. The exact error message is:
Measurements: Write cannot be performed, because the number of channels in the data does not match the number of channels in the task.
In the example you posted, you are doing a single analog write with a DAQ Assistant you called DAQ 9264. Are you using a 9264 or 9263? You mention multiple actuators and a solenoid. Since you are only writing to a single channel, did you post the right code?
Message 6 of 8
(5,462 Views)
well, you are write it doesn't actually say that, it's just what i understood it was happening. But the right message is the one you posted. I am using an 9264 which is the same as 9263 but with more output channels. Yes I am trying to drive 4 devices (a selenoide, and 3 actuators) as my hardware is conected to those. They all need a voltage signal to be driven that's why I am try to run 9264 with 4 or 5 channels at the same time.
The attachment is the current code I have...
Looking forward to hearing from you
Message 7 of 8
(5,447 Views)
Now the error makes sense and the cause is exactly what the message says. You have configured the DAQ Assistant for 4 channels. The input is a single DC signal. You need a signal for each channel.
Message 8 of 8
(5,445 Views)
