Multifunction DAQ
error -200221 in NI 2566 switch when trying to reset device
I am getting this error when trying to init the NI2566 switch in my program.
All has been working fine until I installed CVI 8.01
I do not know if this is the reason but the tester has been working fine up to now..
I have ni2503, NI4060, NI6225 also in the system and they are ok.
If I reinstall the drivers/reboot problem goes away.
- Make Software User Friendly -
(4,211 Views)
First, what drivers are you using?  I would recommend bein g on both the latest DAQmx as well as NI SWITCH drivers.  I have attached the links to both below.  You mentioned that when you re-install the drivers, the problem goes away.  Does it ever re-occur, or has it gone away for good.  If it is coming back, when is it coming back?  First verify that you are using the latest drivers and if you are still having problems, let us know.  Thanks and have a great day!
NI-SWITCH
https://www.ni.com/en/support/downloads/drivers/download.ni-switch.html
NI-DAQmx
https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html
L. Allen
(4,203 Views)
more history:
- yes it is a random fault, it stiil fails sometimes even after I reinstall the drivers..
I already have nidaqmx8.1 and switch 3.1 installed..
I started off with  NI development suite set of CD'd dated FEB 2006...all worked fine
I installed NI development suite set of CD'd dated MAY 2006 and then my problems started..
I changed the switch card and still got the same error within an hour..
I have just installed SW3.1 and we will see what happens.....If it fails, I am going back to SW3.0 version...if I can !!!
(4,192 Views)
I am also seeing this issue with a PXI 2566. Randomly, when starting up the PXI chassis, the system will fail to initialize the card with error -200221. If I close out LabView and TestStand, and attempt to restart the card from MAX, the card is incommunicative. I have two systems which exhibit this behavior, and both are running updated drivers.
If I shut down the PXI chassis and restart the system, it may or may not issue the same error -200221. It can take several attempts at rebooting to resolve the issue. If however, on the first reboot, I go into MAX and reset the 2566, the problem is resolved, until it randomly occurs again. This can take days, weeks, or months.
Any ideas?
BCE
(4,082 Views)
The problem was fixed with my CVI software after I installed NISWITCH331
(4,076 Views)
Thanks! This link describes the bug and subsequent fix:
http://digital.ni.com/public.nsf/allkb/6C620110E954F954862571E0004EC905
BCE
(4,072 Views)
