displacement data filtering
Hello, dear fellows! I am facing a problem as a novice in data acquisition: there is a test rig which consists of, apart from everything else, two displacement sensors, which acquire data of the rotor displacement over time. the data i am recieving is noisy, so i had to filter it. i use butterworth topology of a filter and for a start default settings of high cutoff and low cutoff frequencies. it is a bandstop filter since i checked the signal in frequency domain and found out the bandwidth of noise. a few words on it: there is a metal cyllinder i use to test the sensors. so when i dont move the object, the sensor shows a straight line, which means the signal i need has 0 frequency. that means that any other change in frequency domain would indicate the frequency of noise. i found out it is between apprx 4000 and 4250. but no matter how i tried the signal would not get filtered. the fact is when i send non-dynamic data (orange line lol) to the waveform out of the filter it shows ok but the signal doesnt change over real time. so i built a waveform considering the characteristics such as t0, dt of an initial waveform, but after that i recieve an even more noisy data. it might be ive been trying to solve the problem for too long i stuck at some obvious point, but i no longer have any ideas, so any help would be appreciated. thanks a lot!
______________________________________
i've got a rebel heart
Message 1 of 10
(5,894 Views)
Reading the help of the filter vi (I added a quick mod of your vi:
init/cont controls the initialization of the internal states. The default is FALSE. The first time this VI runs or if init/cont is FALSE, LabVIEW initializes the internal states to 0. If init/cont is TRUE, LabVIEW initializes the internal states to the final states from the previous call to this instance of this VI. To process a large data sequence that consists of smaller blocks, set this input to FALSE for the first block and to TRUE for continuous filtering of all remaining blocks.
Greetings from Germany
Henrik
LV since v3.1
Message 2 of 10
(5,884 Views)
Henrik, thanks for your reply, could you if possible save the .vi so that i could open it with my version of labview which is 2011?
Message 3 of 10
(5,877 Views)
On monday ....
Have a nice weekend 🙂
or think about what I wrote, RTFM isn't that hard 😉
Henrik
LV since v3.1
Message 4 of 10
(5,864 Views)
Okay, sure.
im okay with manuals, but it comes to reading manuals when nothing else works haha 🙂 actually im better at understanding when i see a wrong and a right 🙂 thanks a lot!
Message 5 of 10
(5,855 Views)
Hope you did not forget haha 🙂
Message 6 of 10
(5,806 Views)
Here is the relevant portion of the change: Connect Not Equal to Zero? to the init/cont input of the filter.
Lynn
Message 7 of 10
(5,788 Views)
thanks johnsold for jumping in 🙂
Sorry , I'm currently at a congress (Capetown :D) and have no access to my LabVIEW stuff. And yes, I forgot about it due to all this stuff that needs to be ready before this trip.
Henrik
LV since v3.1
Message 8 of 10
(5,770 Views)
Accepted by pomplamoose
here we go...
Henrik
LV since v3.1
Message 9 of 10
(5,719 Views)
Thanks a lot for your help, Henrik! Cheers!
Message 10 of 10
(5,648 Views)
