Multifunction DAQ
deployment of VI
Hello everybody...
I managed some VI...on my PC & NIDAQ...
I wanna deploy these VI & the NIDAQ...
Can i present these VI under a compiled version which is LVIEW independant???
(3,176 Views)
Hello somebody,
I don't know exactly what you want to do, but:
By ordering the labview application builder, you can create stand-alone executables or DLL's.
If you want some-one else to run your VI, he/she can download the LabVIEW player.
Hope this helps Zico,
Patrick de Boevere
(3,176 Views)
Use the application builder to create an executable.
This will create a stand-alone app that requies only the the LV run-Time engine along with NI-DAQ to support the hardware.
Ben
(3,176 Views)
Zico,
I agree with the answers above. Application builder is part of the LabVIEW Professional Development version but can be added as module to the Full Development version.
You will need to install NI-DAQ and the LabVIEW Run-Time Engine on the target machine. The Run-Time Engine can be installed as part of the application, by default this is enabled once you select to create an installer for the application in LabVIEW 6.1. For the other versions you will have to enable it manually.
I hope this helps
Alejandro Asenjo
Applications Engineering
(3,176 Views)
