12-05-2006 04:47 PM
12-06-2006 05:09 PM
12-10-2006 10:17 PM
Hi Spex! Thanks for your reply~
I have the 7.1 version of DSC with my constants bound to an RSLinx OPC server. Importing the data from Citadel to an excel sheet shows interpolation between what should have been a step change in RSLogix (i.e. getting a ramp as output not a step).
If you can think of anything it could be i would be most appreciative!
Cheers,
Sianny.
p.s. Many apologies for my late reply our internet was down for a few days and then i took a short holiday.. not very considerate of me i know.. so sorry.
12-11-2006 07:31 AM
Question 1:
To save space, DSC only logs changes and then interpolates between points. You can force a database write every so many hours/minutes/seconds by going to Configure-Historical in the Tag Configuration Editor and changing the "Maximum time between logs".
Question 2:
The easiest way to change a group of tags is to Export your .scf file to a .txt, load it into Excel or wordpad, use find/replace (or whatever technique works for you), and Import the new .txt file back into DSC.
Steve
12-11-2006 04:26 PM
Thanks so much for the feedback!
I'll have a go!
