 Tom_SAVU
			Tom_SAVU
			05-25-2007 03:47 PM
05-29-2007 03:30 PM
05-29-2007 03:53 PM
Hi Raajit, thank you for your answer.
The problem is that I have a 2350 and not a 2345.
Here I found that SC-2350 works with Traditional NI-DAQ version 7.4.4.
I wonder which is the correct info: this one or that mentioned by you ?
DAQPad-6052E seems to be also compatible with Traditional 7.4.4.
Do you think I have to install this version of NI-DAQ only and try to program in the traditional style ?
Tom
05-30-2007 06:31 PM
05-31-2007 12:19 AM
06-01-2007 11:10 AM - edited 06-01-2007 11:10 AM
Message Edited by Raajit L on 06-01-2007 11:14 AM
06-03-2007 11:45 AM
Thank you Raajit,
By using 2350 as an accessory I ment:
1. To declare DAQPad-6052E in Traditional NI-DAQ
2. Connect SC-2350 to the DAQ board without declaring the 2350 in MAX
3. Read the voltage at the input channels of 6052E
I have also a second, bigger, problem: I have a TEDS accelerometer connected to a module in 2350.
It seems that first I have to connect the 2350 to a DAQmx board, to read the TEDS data and then to make a traditional VI using the previously read data for converting the measurements.
This is because in the final application I have to use only 6052E and 2350 .....
Tom
 Robert_F
			Robert_F
			06-04-2007 02:42 PM
Hi Tom,
The DAQPad 6052E is only able to work with the Traditional DAQ driver, while the SC-2350 is only able to work with the DAQmx driver. There is no current way to make these two devices communicate or share data between them. This functionality is not supported. We recommend that you use an M series board to communicate with the SC-2350.
