Multifunction DAQ
daqmxreadanalogf64 vb6
Dear all
Could someone explain or give me exemples of continuous aquisition of data in VB6 with daqmx beta functions ?
Up to know all other functions (read/write digital, read/write analog scalar...) work fine. But I'm unable (or i don't know) how to get the data from the reading buffer (continuous mode), in finite mode it's ok.
My goal is to display or write in a file the data.
How to use the loop for displaying the output array and the way this array is implemented through buffer reading ?
In a general maner, do you know where i can find good exemple of code for VB6 in daqmx ?
Thanks for your help.
(2,977 Views)
You will find in the following link the informations you are surching for.
There are examples and documentation about the use of NI-DAQmx in Visual Basic 6.0
http://digital.ni.com/public.nsf/websearch/B22FE2B0F9C8935286256E920073DA07?OpenDocument
regards,
Marc L.
NIF
(2,953 Views)
