Multifunction DAQ
daqmx simulation plateform
Hi!
I work with labwindows cvi and simulated ni cards like 9485. It seems working properly however I would like to check the digital output's states. The max test panel only allows switching lines but not looking the values.
Moreover, I can nont have two tasks on the same port working simultaneously.
How can I check the lines during the execution of my software?
Thanks.
(3,100 Views)
You cannot check the state of simulated digital or analog output. Because it is simulated, there is no way to check that.
Best regards
(3,078 Views)
