Multifunction DAQ
daq connection
can i connect the output pins of  rotary encoder E50S8-360-3-T-24 to NI 6008 daq ?
(2,799 Views)
Hi mamadooo,
You should be able, just make sure that the encoder's output signals comply with the voltage level complies are TTL, LVTTL or CMOS.
It's also possible to read the signal from the AI in which case you'll need to consider the maximum sampling rate and voltage level.
PedroR
(2,761 Views)
