06-05-2007 06:24 AM
06-06-2007 04:39 AM
You could have 2 single Point AO DAQmx writes and perform the required operation independently for each channel
Using the same logic, you could create and array of vaues from 0 to 2.5 with an increment of 0.1 V and do a single point generation inside a loop, by indexing each point
