controlling two outputs of daq with one daq assistant
My DAQ, NI USB 6211 has two analog outputs. I am trying to control both outputs. How can I do this using two separate knobs. I wish ao0 to control x axis and ao1 to control the y axis. Sending both of the signals into the data port does not work, and I have tried creating an array to send in the data. What must be done in order to control both the ao0 and ao1 separately.
Also, once this works I want to create a loop for x values so that the values constantly loop from 0-2.5V in increments of 0.1V. Is this possible? Thank you,
Josh
(2,945 Views)
You could have 2 single Point AO DAQmx writes and perform the required operation independently for each channel
Using the same logic, you could create and array of vaues from 0 to 2.5 with an increment of 0.1 V and do a single point generation inside a loop, by indexing each point
(2,927 Views)
