continuous mutliple analog inputs, DAQ 6229 VB6
I realize to read from more than one analog input on a single board something to this effect must be done:
DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai6,Dev1/ai7","",DAQmx_Val_Diff,-10.0,10.0,DAQmx_Val_Volts,NULL)
which specifies a list or range of channels I wish to read from.
However I'm not sure how to make the appropriate read call if I want to make continuous acquisitions. Do I use
DAQmxReadAnalogF64 or DAQmxReadAnalogScalarF64, and if so can someone tell me explicitly how to access the data for each channel?
Warmest Regards and Praise to whomever can help me.
-Ixs
(2,928 Views)
Thanks to all who replied, I've solved the problem!
-Ixs
(2,919 Views)
