Multifunction DAQ
connector
I have a Lab-PC-1200 with 50 pin port,a terminal box with 68 pin port and a 68F-50M cable adapter. Now I am going to connect the Lab-pc-1200 to the 68 pin terminal box with 68F-50M cable adapter, Please tell me the corresponding pins map. for example, which pin in the 68 pin terminal box corresponds to ACH0(pin 1)on the Lab-pc-1200. Thanks
(2,713 Views)
I found a good webpage that talks about this. Here is the link:
Dimensional Drawings for 68-50 Pin Connector Adapters
On that webpage you will find a link that talks specifically about 68F-50M MIO cable adapter, including the wire list.
Good luck with your application!
(2,713 Views)
