Multifunction DAQ
compile CVI70 code in .Net 2003
Dear Support Team:
I have a visual studio .net 2003 project, use usb DAQmx 6251 for data
acquiring.
I have LabWindow/CVI project using USB 6251.
Do you have any sample to description
integrate CVI code to .Net 2003 project?
How can I invoke the driver in .Net 2003 environment? Do I need setup
special
path ?
Thank you.
(3,140 Views)
Hi Lisa,
There is no way to compile CVI code in .NET. Examples exist for both environments and you can refer to the following KnowledgeBase (KB) to find them for .NET.
NI-DAQmx, NI-VISA and NI-488.2 .NET Example Locations
If you have National Instruments hardware, the all of the drivers and examples will be included with your DAQmx driver CD. You may need to install driver support for .NET which should be automatically detected if you repair the DAQmx driver. Go to the Control Panel in Windows and select the Add or Remove Programs and choose National Instruments software from the list. Find your DAQmx and select Repair. Make sure that you can see support for .NET and that should give you everything you need. Again, refer to the KB for the location of the examples, which will help you get going quickly.
Mark E.
Precision DC Product Support Engineer
(3,124 Views)
