Multifunction DAQ
check sampling rate
i am using a daq assistant for my analog inputs
is there any vis for me to check and verify the sampling rate of the data acquired?
(3,818 Views)
Hello
See attached doc. The real sample rate can be different of the requested one.
Greetings
Alipio
"Qod natura non dat, Salmantica non praestat"
(3,808 Views)
hi
in addition to the above question
if i am using the above daq assistant as an input to a transfer function can I just connect the reciprocal of the sampling clock rate to the dt of the transfer function vi?
(3,804 Views)
hi again
Yes, that sample rate is samples per second per channel.
If your vis use waveform input, conver dynamic data to waveform. This type of data includes timestamp,dt and data.
See attached doc.
Greetings
Alipio
(3,800 Views)
thanks for your help
anyway can i use the dt from the dynamic data instead of getting the reciprocal of the sampling rate and connect it to the dt of the transfer function?
(3,798 Views)
Hi
Yes, you can use dt as input to other vis and its reciprocal as confirmation of sample speed for channel.
Greetings Alipio
(3,795 Views)
