キャンセル
次の結果を表示
次の代わりに検索
もしかして:
check sampling rate
i am using a daq assistant for my analog inputs
is there any vis for me to check and verify the sampling rate of the data acquired?
0 件の賞賛
メッセージ1/6
3,821件の閲覧回数
Hello
See attached doc. The real sample rate can be different of the requested one.
Greetings
Alipio
"Qod natura non dat, Salmantica non praestat"
メッセージ2/6
3,811件の閲覧回数
hi
in addition to the above question
if i am using the above daq assistant as an input to a transfer function can I just connect the reciprocal of the sampling clock rate to the dt of the transfer function vi?
0 件の賞賛
メッセージ3/6
3,807件の閲覧回数
hi again
Yes, that sample rate is samples per second per channel.
If your vis use waveform input, conver dynamic data to waveform. This type of data includes timestamp,dt and data.
See attached doc.
Greetings
Alipio
0 件の賞賛
メッセージ4/6
3,803件の閲覧回数
thanks for your help
anyway can i use the dt from the dynamic data instead of getting the reciprocal of the sampling rate and connect it to the dt of the transfer function?
0 件の賞賛
メッセージ5/6
3,801件の閲覧回数
Hi
Yes, you can use dt as input to other vis and its reciprocal as confirmation of sample speed for channel.
Greetings Alipio
0 件の賞賛
メッセージ6/6
3,798件の閲覧回数
