Multifunction DAQ
channel shift
I'm using a USB-6259 and have configured a task in MAX for Ai1, Ai2, Ai3, Ai4, Ai5, Ai7, Ai8, Ai9, Ai10, Ai11 and when I run the task under MAX the channels are shifted down one meaning the table view list them as follows:  Ai11, Ai1, Ai2, Ai3, Ai4, Ai5, Ai7, Ai8, Ai9, Ai10 I verified this by physically monitoring the voltage at the DAQ screw terminal. I connected a different DAQ A USB 6212 and no problem c hannels list correctly. Im running  NI Device Driver Auguest 2015 version 15.  When I set up yhe task in LabView I see the same shift.
(4,510 Views)
Hi there,
Thanks for posting on the NI forums! If you connect this piece of hardware to another computer and configure a task do you see the same channel shift in MAX? Just to confirm, you are using DAQmx version 15.0, correct?
Tina
Applications Engineering
Tina K.
ni.com/support
(4,476 Views)
Yes I connected another computer and saw the same shift I was able to resolve the problem selecting Reset Configuration Data Under the Tools menu option in max.
Thanks for your replay
(4,467 Views)
Happy to hear you got it working!
Tina
Tina K.
ni.com/support
(4,463 Views)
