Multifunction DAQ
cdaq-9172
I'm using a cdaq-9172 with a NI 9421 input card. I want  to look at the first 4 bits as an integer and see this in the shared variable engine. Any thoghts on how I could do this? I have tried making a new Global virtual channel but can only select input, or port input. Port input is a bool and not integer.
(3,924 Views)
You will need to build your data into a boolean array and convert to a number.  Then you can turn that value into a shared variable and see the number rather than the boolean.  Hopefully this helps!
h_baker
(3,902 Views)
Thanks for the input..It is working for me but I have another problem. I want this app to run when started so I used a while loop instruction. With the while loop the number does not update it stays at Zero. I can see the boolean switches working but that is all.  Any thoghts?
(3,875 Views)
Accepted by topic author kmarcoux
Problem solved..Was not puting everything inside the while loop.
Thanks for your help!!!
Kevin
(3,871 Views)
