can i use a cb-50lp(connector block)with pci-6025E(DAC)
hi,
Can i use a cb-50lp(connector block)with pci-6025E(DAC) USing a 100-5050 ribbon cable,please help in this regard.
(4,422 Views)
Yes, I have done that in the past. Look at the pinout of the card, with only using (1) CB50, only half of the I/O will be available (I think it was split between analog and digital)
(4,418 Views)
Yes you can split the output of the 6025E into two 50's as you have described.  I have also done this in the past (on more than one application). Positions 51 thru 100 on the 1005050 cable are the extended digital lines PA (0 to 7) thru PC (0 to 7).  The position 0-50 cable has everyting else.  I have used a 24 postion relay rack on the 51 thru 100 cable in the past as well.  See the attached word document for the actual pinouts from my application.
(4,207 Views)
I have also done this many times in those "old" series E days...
(4,200 Views)
I also want to use CB-50lp with 6025e but CB-50lp is not an accessory option when configuring.  Do I leave it at none or pick something else?
(3,267 Views)
I think you can just leave this set to none.
(3,263 Views)
