Multifunction DAQ
can i use PCI 6115 both as an output and input device simultaneosuly?
I would like to use PCI 6115 data acquisition card from National Instruments for both generating a signal and then configure it for receiving the generated signal. I am using MATLAB program.I ran a program and it shows no error. But the results are not what I expected. Any help will be appreciated
(2,541 Views)
The PCI-6115 can receive and generate signals. It can actually do both at the same time. However, this depends on how it is programmed. Since you are using MATLAB, I do not know what I can do to help. Are you making calls to NIDAQ32.dll?
Please post any follow questions or maybe some more information on what you are seeing.
Justin T.
(2,541 Views)
