Multifunction DAQ
audio sampling using labview
Hi
I was wondering if anyone can give me some information regarding audio sampling using labview. I'm interested in sampling an audio signal and storing it in the computer as some format. The format can be raw or hi-resolution like mpeg etc. (that's not the problem). Also, I currently have PCI-6229 (Data Acquisition) card setup with labview. Do you think this card will work fine for audio sampling or do I need to buy a seperate NI card for audio sampling? And is labview compatible and preferred for this?
(3,114 Views)
I found a past post from someone experienced with audio sampling that may answer your question:
http://forums.ni.com/ni/board/message?board.id=170&message.id=40154
Because the M Series boards similarly use multiplexed ADCs the same concerns will apply to the PCI-6229. If you are only sampling one channel at a time, then it should be just fine. Simply perform an analog voltage measurement.
Good luck,
Jason
(3,091 Views)
