attach two arrays
i have two arrays that i want to attach end to end.  if i use build array it creates an appended array which is not what i want.  essntially im performing the opposite of a split array.  are there any functions that match this description?
(3,223 Views)
Use Build Array. Did you right click on it and select 'Concantanate Inputs'? Do you run LabVIEW with the Context Help window open?
(3,219 Views)
Accepted by acgraham
actually i just found that "insert into array" worked for me.  ill try you method too next time
(3,206 Views)
