Multifunction DAQ
acquisition with encoder and daqpad 6070e
Hello!
I am working with a Daqpad 6070e and Labview 7.1.  I have 1 ppr (pulse per revolution) encoder and a 360 ppr encoder.
When I work with the 1 ppr I need to simulate the 360 ppr encoder to acquire N channels (at the maximun sample rate) each degree of the shaft. I don't know what is the best way to do this.
With the 360 ppr I think I have to use the external scan clock but I am a little confused because I don't really know the difference between external clock and external channel clock.  I need the same as the 1 ppr encoder, this is, each pulse I need to acquire the channel list as fast as possible.  I will be very greateful if someone help me.
Thank you in advance.
Message 1 of 1
(2,879 Views)
