‎03-27-2009 11:21 PM
‎04-15-2009 08:05 AM
Hi Bharath-
Visual C# .NET is not supported. The only supported development environment for DAQmx Base on Windows CE is LabVIEW. For the version you're using (NI-DAQmx Base 3.2), you'll need LabVIEW 8.6 and the LabVIEW 8.6 Mobile Module. This type of information can be found in the readme.
I hope this helps-
Ed
‎04-15-2009 08:41 AM
Thanks for the suggestion.........Slight update in my question
I programmed in Visual C++ including the Nidaqmxbase.h file provided by NI. It successfully compiles but gives around 200 linker.
What seems to be the problem?
Thanks in advance.
