01-11-2006 12:49 PM - edited 01-11-2006 12:49 PM
Message Edited by jdebuhr on 01-11-2006 12:51 PM
01-12-2006 10:06 AM
Jeff,
Thank you for contacting National Instruments. From your description, it looks like you want to do two edge separation measurements between two signals in many different variations. Unfortunately, the hardware you have is not able to to do this. These measurements require counter inputs. Only your 6036 has counter inputs, and it only has two. But also, the hardware of those counters will not be able to measure the separation of two separate signals. I would recommend that you take a look at the Meas Two Edge Separation, Meas Two Edge Separation-Buffered-Continuous, and Meas Two Edge Separation-Buffered-Finite examples in the LabVIEW 8 example finder. You will see the hardware that is necessary to run those examples in the Requirements section of the example finder. Your best option may be a 6601(4 Counter) or a 6602 (8 Counter) board. If you would like, I can have someone send you a quote for both of these. If you have any other questions, please do not hesitate to contact us. Thanks and have a great day!
Lon
01-12-2006 10:44 AM
