 Joseph92
			Joseph92
			04-16-2015 01:12 PM
04-17-2015 11:43 AM
There is a thread where another person had a similar issue to your problem. There are some steps that you could try listed in there. Could you see if these steps work for you?
This is the thread http://forums.ni.com/t5/Multifunction-DAQ/Error-88705-with-a-USB-6366-DAQ/td-p/1861203.
04-20-2015 03:39 AM
Good morning Inachosa,
Thanks for your reply, unfortunately, I do not have access to the referred thread. Thanks
04-21-2015 11:12 AM
I am sorry it seems that I pasted with a misspelling. Here it is
04-27-2015 06:10 AM
Thanks, but still I did not solve the issue. I have implemented the improvements show in the table below without any success. As shown in the screenshot the error is still encounter
| Improvement | Link | Result |
| 2 port configuration | http://digital.ni.com/public.nsf/allkb/AC929F0881D9178A862578B000586491 | Error 88705 |
| NI Device Loader | http://digital.ni.com/public.nsf/allkb/0819391CA91B3EB38625731D00024649 | Running /Updated but error 88705 still unsolved |
| NI mDNS Resp Ser | “ “ “ | Running /Updated but error 88705 still unsolved |
| NI Configuration Manager Service | http://forums.ni.com/t5/Multifunction-DAQ/NI-USB6211-Error-88705/m-p/2371998/highlight/true#M76206 | Running /Updated but error 88705 still unsolved |
| Resetting MAX Database | http://digital.ni.com/public.nsf/allkb/2C7480E856987FFF862573AE005AB0D9 | Error 88705 |
| Firewall off |
 | Error 88705 |
 Guillermo.O
			Guillermo.O
			10-07-2015 05:34 PM
Hello Joseph92,
I just found a very similar case, where the error was resolved by repairing NI DAQmx and NI LabVIEW. You can do this by going to the Control Panel/Uninstall or change a program/Software of National Instruments, then choose all DAQmx and NI LAbVIEW options and finally click on repair.
It seems that the problem is with a configuration of web services of LabVIEW. And repairing the software fix this problem.
Greetings and let me know if this was useful
Guillermo O,
