What is input equivalent circuit of USB 6009 PFI0
Is the USB 6009 PFI0 input the same as the analog circuit input shown in the user manual?
I am using the PFI0 to trigger a voltage measurement and it works great using an HP function generator.
When I try to drive the input low with my circuit it looks like there is a pull up resistor to +5 on the PFI0 input terminal.
Will this PFI0 input accept a 0 to 15 volt comparitor output with being damaged?
Kip
(3,600 Views)
After looking at the user manual again, I am guessing that the PFI0 is speced as the other digital input teminnals with a 4.7k resistor to +5. Can you confirm this. Looks like I will have to convert my cmos digital output to TTL.
Can any body confirm this?
(3,591 Views)
Accepted by topic author kscholl
Here's my solution to drive the PFI0 TTL digital input using a CMOS comparator.
I am using a 2N4401 npn transistor.
Connect the Emitter to the ground terminal.
Connect the Collector to the PFI0 terminal (there is a pull-up resistor internal to the 6009).
Connect the Base to a voltage divider that limits in input current and drops the CMOS voltage to TTL levels.
In my case I am going from 0 to +15 so my voltage divider is 4.7k and 2.2k ohms to drop it down to 0 to +5 volts.
This is an inverting circuit so your trigger sense will change from rising edge to falling edge, or vice versa.
I hope this helps someone out.
Kip
(3,577 Views)
