‎08-25-2005 03:21 AM
‎08-25-2005
09:23 AM
- last edited on
‎07-13-2025
03:26 PM
by
Content Cleaner
You can get an evaluation copy or try version 7.1 online. As far as drivers, what type of driver are you talking about? Is this for a non-NI DAQ board? If it is, do you already have the windows driver (i.e. a DLL) and need to create a LabVIEW interface to it? If it's an NI DAQ board, then the drivers already exist and you can create application programs with LabVIEW. A few more details would be nice such as the exact nature of the DAQ boards and what your task is.
‎08-30-2005 12:49 AM
‎08-30-2005 12:57 AM
‎08-30-2005 10:26 AM
An NI DAQ board is a data acquisition board from National Instruments. Who exactly is the manufacturer of your board? What is the model number?
Assuming that the board is not from NI, then the manufacturer provides a low level driver (usually a DLL) that you have to access from LabVIEW. This is done with the Call Library Function Node on the Advanced palette. In order for this to work, you need detailed documentation on the DLL from the vendor. This will include a description of each function in the DLL and the calling parameters. Go to Help>Search the LabVIEW Bookshelf> and open the "Using External Code in LabVIEW" document for details on using the Call Library Function Node. Note that using this is usually not a trivial task and I wouldnt' necessary recomend it for a beginner but it could be done. If you're lucky, you may find someone here who has already done this for your particular board. That's why it's important that your provide this information.
Instrument/Plug&Play drivers usually refer to instruments such as scopes, meters, function generators, etc. that are connected to the PC with GPIB/USB/Serial/Ethernet interfaces. The protocols for communication with these instruments is much simpler and usually consist of sending text strings to the instrument.
