Multifunction DAQ
VC++ code for reading simulated devices
Hello
I am using Microsoft Visual C++ 6.0 and using C API's provided in NIDAQ861.exe. The code i write  to read single analog input simulated channel of simulated PCI 6255 device is given below.
#include<NIDAQmx.h>
#include<iostream.h>
#include<stdio.h>
int main(void)
 FILE *fptr;
 fptr=fopen("NI_test1.bin","wb");
 TaskHandle  taskHandle=0;
 int ch_no=1;
 char        chan[256] = "Dev1/ai0";
 float64     min = -1, max = 1;
 char        clockSource[256] = "";
 float64  rate =3200;
 int samp_per_chan = 20000;
 int32 *s1;
 s1 = new int32[samp_per_chan];
 double *dat1;
 dat1 = new double[ch_no*samp_per_chan];
 bool32 *dat;
 dat = new bool32[256];
 DAQmxGetDevIsSimulated(chan,dat);
 cout<<*dat<<endl;
 DAQmxCreateTask("",&taskHandle);
 DAQmxCfgSampClkTiming(taskHandle, clockSource, rate, DAQmx_Val_Rising, DAQmx_Val_FiniteSamps, samp_per_chan);
 DAQmxCreateAIVoltageChan(taskHandle ,chan ,"", DAQmx_Val_RSE, min, max, DAQmx_Val_Volts, NULL);
 DAQmxStartTask(taskHandle);
 DAQmxReadAnalogF64(taskHandle, samp_per_chan, 10.0, DAQmx_Val_GroupByChannel ,dat1, ch_no*samp_per_chan, s1, NULL);
 fwrite( dat1, sizeof( double ),ch_no*samp_per_chan,fptr );
 DAQmxStopTask (taskHandle);
 DAQmxClearTask (taskHandle);
 delete [] dat1;
 delete [] s1;
 fclose(fptr);
 return 0;
First, Kindly tell me if there is any thing wrong in this code?
Now i read the binary file generated above(NI_test1.bin)  in MATLAB and plotted it, it show me 20 cycles of sine wave with each cycle consisting of 1000 points. After this i plot its frequency spectrum (using PSD of MATLAB with fs=3200, fft_siz=1024) , i could not see any particular peak at any frequency ?
Kindly  explain if anything wrong with this approach? and how  frequency spectrum should look like in above case?
(3,198 Views)
The peak values for this situation of simulated data should be around 3.2, since your rate is 3200 S/s.  What are you seeing if you are not seeing a peak?  Please provide a screenshot of the results.
Samantha
(3,171 Views)
