Multifunction DAQ
Using same DAQ device with more than one PC
Dear LabVIEWers,
I have a question that is related to the data acquision using more than one PC. I want to use a single DAQ multifunction board for sharing with more  than one PC. Specifically, I have three clones of an experimental setup which I need to connect to a single DAQ board, which in turn needs to be connected to three PCs. Is this possible ? I look for solutions other than RDA-based data acquisition. What all hardwares do I need to do it?
Many thanks in advance,
zacharia
(2,913 Views)
Hello Zacharia,
It sounds like you would be interested in NI-DAQmx OPC Capabilities.  If you have LabVIEW 8.0 it's very easily done with the Network-Published Shared Variable.
The requirements to use NI-DAQmx OPC Capabilities are a hardware board that uses NI-DAQmx, which you can find using the NI-DAQ Driver Support page or by talking with one of NI's Sales Reps.
If this does not completely answer your question, post again and we'll try to help out further.
Micaela N
(2,902 Views)
