Multifunction DAQ
Using Calibration Executive with more than one NT user
The Calibration Executive appears to install for the current user only. If you try to run it when logged in (to NT) as another user a database error occurs due to a key not being present in the registry. Is there a way around this.
We have several engineers working in the cal lab and we do not want to have to install it on the same machine for each of them as it takes about 15mins to install.
We have another problem that has just appeared as well. When generating a html report, the report is created and written to the file in the templated directory but then the Calibration Executive crashes out when (I think) trying to open the browser (IE6.0). we have reinstalled the Executive and IE but is has not fixed the
problem. The html file itself is created OK. The problem is not apparent when using the text file output option.
Message 1 of 1
(2,550 Views)
