Multifunction DAQ
Using Agilent 34970A in LabView yields error code -1073807343
Trying to get the Agilent to successfully work on Labview. I've tried programming using the latest Labview (version 8.#) as well as on Labview version 6.1 -- both give me the same results. I'm suspecting this is a driver conflict, not Labview itself...perhaps something between VISA and HP's Agilent? My visa version is 4.5 which is up to date. The hardware works; I used the troubleshooting Wizard and it gave me a go.
LabView shows:
'Error -1073807343 occurred at VISA Open in HP34970A Initialize.vi->Untitled 1
Possible reason(s):
VISA:  (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system. '
NI Spy shows:
> 3.  viOpen (0x00F01000, "GPIB0::9::INSTR", 0, 0, 0x00000000)
> Process ID: 0x00000208         Thread ID: 0x01197000
> Start Time: 14:43:25.586       Call Duration 00:00:00.008
> Status: 0xBFFF0011 (VI_ERROR_RSRC_NFOUND)
Message 1 of 17
(6,971 Views)
First, you posted to the wrong board. This board is for NI DAQ hardware. You should have used the Instrument Control board.
Second, what exactly do you mean by a conflict 'between VISA and HP's Agilent'? The company called Agilent used to be part of the compary called HP. I used a lot of 34960 and a few 34970 with never a problem. What type of connection are you using? If it's GPIB, are you using an NI GPIB controller? Is the instrument listed in MAX? What troubleshooting wizard for what hardware works?
Message 2 of 17
(6,971 Views)
Sorry. I'm using a NI GPIB-USB-HS controller. Thanks for your time. What do you think is the problem?
NI-488.2 troubleshooting wizard
NI-488.2 Software Presence Verified
GPIB Hardware Presence Verified
GPIB Interfaces Sequentially Verified
interface name  interface type status
GP1B0      GPIB-USB-HS      passed
Message 3 of 17
(6,964 Views)
I'm also using Mac OS X
Message 4 of 17
(6,959 Views)
Did you do a scan for instruments and does the instrument appear in MAX? If it doesn't, then it won't do  any good to try to run any LabVIEW code.
Message 5 of 17
(6,953 Views)
It appears when running the Interactive Control on the Mac, i have 2 listeners @ address 0 and 9 but I'm not sure which instruments they are.
Message 6 of 17
(6,929 Views)
I don't really care about interactive control in MAX. It does not matter if that does or does not work there. You need to do a scan for instruments and the instrument has to show up there. You need to do this in order to populate the visaconf.ini file. the interactive control does not use VISA. The instrument driver does.
Message 7 of 17
(6,925 Views)
Where can i do a scan for instruments?
Message 8 of 17
(6,922 Views)
It's weird....my driver is up to date yet computer sees the connection as a PXI/PCI instead of a USB. It should be a USB right?
Message 10 of 17
(6,920 Views)
