Multifunction DAQ
Understanding the Calibration Wizard and Calibrations of Global Virtual Channels
Please refer to the attached word document "UnderstandingNICalibrations.doc" for screen captures and a full explaination showing how I tried to determine some answers to the questions stated below.
I want to use the Calibration Wizard feature available in MAX (via the NI-DAQmx DAQassistant), but I need to understand how the calibrations I enter are applied to the measurements. The reason I need this understanding is so I may determine the error/goodness of fit of the resulting correction from the calibration.
Please, will someone tell me how these calibration corrections work (how do I determine the error)?
I reviewed the LabVIEW help for the channel calibration property node and was able to determine that the Calibration Wizard sets up a calibration curve with the Table (10450) method. However, I do not understand what the second part of the explanation for the Table method "with all other values scaled proportionally" means. How does the calibration method interpolate/extrapolate between/beyond points on the table?
I created a NI-DAQmx task to read current measurements. In this task I specified two virtual channels that are connected to the same physical channel (the physical channel is from a simulated PXI-6225 device). My plan was to apply a calibration to one virtual channel and not the other so that I could visualize the difference between a calibrated signal and an uncalibrated signal.
In summary, I have the following questions I would greatly appreciate some answers to:
1)        How do I quantify the error of the calibration correction if I use the Calibration Wizard tool?
2)      For the Table calibration method, how does the method interpolate/extrapolate between/beyond points on the table?
3)    Why do I not observe the expected difference in the calibrated and uncalibrated signals when I set up a task to do so?
(4,436 Views)
Thank you for posting to the National Instruments Discussion Forums.
I do not know the answer to your question right now, but it is a very valid one. I am digging through our documentation here and will let you know what interpolation techniques are used as soon as I find something.
Thanks again,
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(4,398 Views)
It seems like the calibration wizard uses a linear interpolation between points to determine values. If you would like more accuracy you can define more calibration points in your table.
Abhinav T.
(4,352 Views)
Abhinav,
Thank you for this information, I appreciate it.
(4,348 Views)
