04-28-2014 01:52 PM
How does the speed of USB DAQ devices compare to the speed of PCIe cards (analog and digital)?
By that I mean if a USB DAQ can take X measurements per second and a PCIe card can take Y measurements per second,
how do X and Y compare to each other?
04-28-2014 02:36 PM
If it is the same model number, they are equal. I highly recommend going with PCI(e) anyways since I seem to have nothing but problems with USB (it got unplugged, Windows decided to remove USB bus power, etc etc et).
04-28-2014 02:41 PM
Thanks for the reply.
I want to move from C# and/or LabWindows and give a project a go with C++. USB devices are eaiser to interface with.
04-28-2014 03:13 PM
Not really. DAQmx takes care of it all for you. So there is not really any difference other than the initialization (where you define which channels to be in a task).
