Multifunction DAQ
USB-6212 install error, Data Invalid
I am trying to use a USB-6212 with LabVIEW 8.5.1 and DAQmx 8.7.1.  When I plug the USB cable in I get the usual prompt to install the drivers for it.  But I get a message that says "The data is invalid" and that the device did not install properly.
Any ideas?
(4,610 Views)
Accepted by _Bryan
Nevermind.  I reinstalled DAQmx and it worked.
(4,603 Views)
If you're on an XP machine, there's a microsoft hotfix available that addresses invalid/missing data... is that what you're seeing?
MAX will alert you to the missing hotfix/potential problem with a yellow "!" in the device tree.
(4,595 Views)
