Multifunction DAQ
USB 6212 Linux
Bonjour,
Could you please confirme me that there is no driver for linux using USB6212 ou USB6002
Cordialement,
(2,062 Views)
USB-6212 and USB-6002 use DAQmx drivers
DAQmx drivers are available for certain Linux distributions as per this article
https://www.ni.com/en-us/support/documentation/supplemental/18/downloading-and-installing-ni-driver-...
https://www.ni.com/en-us/support/downloads/drivers/download.ni-linux-device-drivers.html#350003
Programming using DAQmx on Linux - https://www.ni.com/en-us/support/documentation/supplemental/21/programming-data-acquisition-for-linu...
Santhosh
Soliton Technologies
(2,054 Views)
Thanks for your answer.
I try to install the drivers DAQ base on my linux OSuse lp15.1 and Ubuntu 18.04
But I did not find the /usr/local/natinst/daqmxbase/
/usr/local/natinst> ll
drwxr-xr-x 1 root root 38 7 sept. 12:08 LabVIEW-2020-64
drwxr-xr-x 1 root root 104 6 sept. 14:37 share
I probably misunderstood the daqmx and daqmxbase !
10 years before, I was installing daqmxbase on OpenSuse 13.1
Now, I understood, we have to use the package manager to deal with the drivers.
In attachement is a list I installed on my OpenSuse.
What about the lsdaq I need in the paste to find my USB device ?
Cordialement
(2,030 Views)
Accepted by topic author Frcstg
I can confirm that at the moment DAQmx on Linux does not support USB-6212 or USB-6002.
(1,946 Views)
