Multifunction DAQ
USB 6008 temperature control
I was wondering if anyone could help me with the following:
I am considering to use the NI USB 6008 DAQ module for a PT-100 temperature control system.
I was wondering if the following would be possible?
My plan is to use a PT-100 element connected to a Wheatstone bridge and powered by a 12V DC power supply. The bridge is then connected to the USB module via the NI connectors. This is then duplicated as I want to measure 2 temperatures. Then, Labview will calculate the temperature and operate a relais with PID control, controlling some kind of heat element.
What is the input signal for the module though? The wheatstone bridge will give some kind of current value (4-20mA), does the module translate this into 0-5V? Or can this be configured otherwise? Thanks.
Bart Gzik
(3,532 Views)
Anyone?
(3,499 Views)
The USB 6008 only measures voltage.  You have to measure voltage across a resistor to get current.  A 250 ohm resistor will give you 1-5 VDC for a 4-20mA signal.
(3,495 Views)
