05-28-2010 08:44 AM
Does anyone know that manufacturer, part number, and a source for the mating connector to the ones on the USB-6008?
05-28-2010
11:35 AM
- last edited on
05-07-2024
10:10 AM
by
Content Cleaner
I would suggest using the USB-6008/6009 accesory kit.
Todd V
05-28-2010 12:05 PM
05-28-2010 12:09 PM
05-28-2010
12:17 PM
- last edited on
05-07-2024
10:11 AM
by
Content Cleaner
The accessory kit that I was referring to isn't the prototyping kit. It includes four connectors, two labels and a screw driver. You can connect your circuit board directly to the connector.
Todd V
05-28-2010 03:38 PM
I was planning to have a board with the mating connector soldered directly to it much like the protyping board. That is why I was inquiring about the connector.
05-31-2010 03:02 PM
To answer your question they are Phoenix Contacts Connectors. If it is a 16 pin connector then this is the mate. 1803714
Otherwise check with folks like Newark and do a search on that part to get to the correct catalog page.
06-01-2010 08:55 AM
The connector I am looking for is the one used on the USB-6000 Series Prototyping Accessory.
06-02-2010 07:15 AM
06-02-2010 09:32 AM - edited 06-02-2010 09:37 AM
So you either want 1786543 or 1786080
one is straight one is right angle.
go to
http://www.phoenixcontact.com/usa_home
and enter the part numbers
Good luck buying less than quanties of 50 unless you can find a stocking distributor. Allied Electronics carries the brand as do many others.
Can I have a cookie now. . . . . . How do I get myself sucked into this?
