Multifunction DAQ
USB-6001
I am very lost. I want to acquire several temperature readings from a setup using thermocouples, as well as some voltage and current measurements. I have a USB-6001, but from what I’ve learned, it’s not the most suitable device since it lacks CJC for the thermocouples and signal conditioning. As a result, I cannot read the thermocouple signal because it is in the millivolt range. Additionally, it does not have CJC. On top of that, the voltage I need to measure is around 0.3V (300 mV), so I’m also unsure whether I can read it without prior signal conditioning. What should I do?
Message 1 of 9
(1,703 Views)
You need to buy a new set of hardware to do the thing correctly.
In your case, a cDAQ will be a better fit as you can mix and max modules that are best suited for each type of signal than a universal one.
Can you describe your application and number of required channels for each signal type?
Santhosh
Soliton Technologies
Message 2 of 9
(1,679 Views)
I'm very new to all these topics, basically I would like to read 3 temperature signals around 40ºC with type J thermocouples. For the voltages and currents, which are in the order of (1000-50)mV, I have been able to obtain them directly without signal conditioning. I understand that I need 3 differential analog inputs (AI+ / AI-) for the thermocouples and 4 others for voltages/currents. I have 2 DAQ USB-6001 and a DAQ USB-6212. Buying additional hardware would not be an option, as I am an intern with a very limited budget.
Thank you
Message 3 of 9
(1,675 Views)
USB6212 is best suited for your mixed application, given you cannot buy new hardware.
Santhosh
Message 4 of 9
(1,664 Views)
First of all, thank you for your time; I wasn’t expecting to receive a response. To wrap up the matter, and if it’s not too much trouble, could you guide me on the hardware I should use to condition the signal? Is there any affordable module that can do it easily? Additionally, I plan to use a thermocouple as a CJC since my DAQ doesn’t have an integrated CJC.
Message 5 of 9
(1,656 Views)
Hi there,
You can get this small thermocouple amplifier, I've seen it used with Arduino all the time.
https://www.adafruit.com/product/1778
Just replace Arduino with your USB DAQ.  See here for instructions on how to convert voltage into degrees C: https://learn.adafruit.com/ad8495-thermocouple-amplifier/arduino
BR
John
Add motion to LabVIEW in 30min or less - TENET EMotion
Finding it hard to source legacy NI hardware? Try Extend Test
Message 6 of 9
(1,612 Views)
Thank you!
Message 7 of 9
(1,605 Views)
How do you replace the Arduino with the USB DAQ?
Message 8 of 9
(591 Views)
Hi Bensut,
From Adafruit's site, this is the description about the thermocouple amplifier:
"The AD8495 K-type thermocouple amplifier from Analog Devices is so easy to use, we documented the whole thing on the back of the tiny PCB. Power the board with 3-18VDC and measure the output voltage on the OUT pin. You can easily convert the voltage to temperature with the following equation: Temperature = (Vout - 1.25) / 0.005 V. So for example, if the voltage is 1.5VDC, the temperature is (1.5 - 1.25) / 0.005 = 50°C."
So, just connect the Vout and GND pins from this thermocouple amplifier to a Analog Input channel on your DAQ, and you'll be ready to go.  Give it a try, and tell us about your results!
BR
John
Message 9 of 9
(563 Views)
