Multifunction DAQ
USB-6001
I am very lost. I want to acquire several temperature readings from a setup using thermocouples, as well as some voltage and current measurements. I have a USB-6001, but from what I’ve learned, it’s not the most suitable device since it lacks CJC for the thermocouples and signal conditioning. As a result, I cannot read the thermocouple signal because it is in the millivolt range. Additionally, it does not have CJC. On top of that, the voltage I need to measure is around 0.3V (300 mV), so I’m also unsure whether I can read it without prior signal conditioning. What should I do?
(962 Views)
You need to buy a new set of hardware to do the thing correctly.
In your case, a cDAQ will be a better fit as you can mix and max modules that are best suited for each type of signal than a universal one.
Can you describe your application and number of required channels for each signal type?
Santhosh
Soliton Technologies
(938 Views)
I'm very new to all these topics, basically I would like to read 3 temperature signals around 40ºC with type J thermocouples. For the voltages and currents, which are in the order of (1000-50)mV, I have been able to obtain them directly without signal conditioning. I understand that I need 3 differential analog inputs (AI+ / AI-) for the thermocouples and 4 others for voltages/currents. I have 2 DAQ USB-6001 and a DAQ USB-6212. Buying additional hardware would not be an option, as I am an intern with a very limited budget.
Thank you
(934 Views)
USB6212 is best suited for your mixed application, given you cannot buy new hardware.
Santhosh
(923 Views)
First of all, thank you for your time; I wasn’t expecting to receive a response. To wrap up the matter, and if it’s not too much trouble, could you guide me on the hardware I should use to condition the signal? Is there any affordable module that can do it easily? Additionally, I plan to use a thermocouple as a CJC since my DAQ doesn’t have an integrated CJC.
(915 Views)
Hi there,
You can get this small thermocouple amplifier, I've seen it used with Arduino all the time.
https://www.adafruit.com/product/1778
Just replace Arduino with your USB DAQ.  See here for instructions on how to convert voltage into degrees C: https://learn.adafruit.com/ad8495-thermocouple-amplifier/arduino
BR
John
Add motion to LabVIEW in 30min or less - TENET EMotion
Finding it hard to source legacy NI hardware? Try Extend Test
(871 Views)
Thank you!
(864 Views)
