USB-6001 Terminal MPN
I would like to order some of the terminal sockets that plug into the USB-6001. Can you please share the MPN for either the socket that is on your board or the terminal that plugs into it? I have asked this before but did not receive a reply.
The terminal strip whose part number I am seeking is shown in the image below.
Thank you,
Ben
(1,972 Views)
Accepted by topic author nibcuf
This is NI PN 782703-01 for a kit of 4 connectors, labels and a screw driver.
If you're looking for a Manufacturer part number, unfortunately, it is not available in the public domain. If someone else has figured it out, they might reply. Typically NI uses Phoenix connectors on their products.
Santhosh
Soliton Technologies
Only two ways to appreciate someone who spent their free time to reply/answer your question - give them Kudos or mark their reply as the answer/solution
(1,962 Views)
Thanks - this is just what I was looking for. MPN is not needed if we can purchase them from NI.
(1,960 Views)
